SOURCE: oven door locked E1 F5
hi..
The manual says F5 means "failed circuit in control". This means that
the control panel is burned out.. So just replace this..
Thank u
rate me!!
SOURCE: When I try to start the self-cleaning oven,
there are switches under the cooktop that go bad frequently. i do not recommend ever using the self clean mode in an oven. the oven gets so hot that things have a tendency to melt because they dont build stuff like they used to. there is inadequate insulation in modern ovens. use easy off and follow the label directions. it'll be cheaper in the long run, trust me.
Testimonial: "What you have suggested makes sense to me. Thank you!"
SOURCE: We tried using the self clean on our Whirlpool
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
SOURCE: I did a self-clean session and the oven remained
I hit the cleaning button instead of the broiler and the oven lock went in mode so now it thinks it is cleaning but I can't close it and it won't shut off the cleaning mode. What can I do?
SOURCE: turned elec range to clean shpws E1 F5 and not
Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction. If you have an electical malfunction with any of these parts, you may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct parts out to you asap.
Thanks, Ella
