SOURCE: where do I find the pcb on a Bosch dishwasher clas...
Check at front door top. You may have to open the screws around the door.
SOURCE: BOSCH WFMC3200 Washer - Receiving
there is small hole in the cover you need to push a small screwdriver or ice pick works in the hole and then turn clockwise till it comes off.
But there will be some water come out so if you have a wet dry shop vac then use it on the end of the drain hose to remove most of the water then keep it handy when you take the plug out there will still be some water come out and you should be able to clena out the trap area
