Question about Panasonic Audio Players & Recorders
Wat causing my panasonic stereo displaying f61 ?
6ya staff
SOURCE:
Anonymous
  • 624 Answers
SOURCE: POSSIBLE FAULT CODE
Yes, it is possible. The F61 error is a failure in the power supply or the amplifier. I repair these every day and it will require good soldering and troubleshooting skills to fix this yourself.
If you would like to try, let me know, and I will give you more information. But the best thing to do is take it to a service center and let a professional technician check it out for you.
Posted on Jul 01, 2008
nuwan chinth
nuwan chinthaka
  • 111 Answers
SOURCE: panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
Posted on Jan 15, 2009
Anonymous
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
Anonymous
SOURCE: F61 code error
I had this problem! Panasonic 5CD Hi Fi. I opened the case to get a look at the circuits and noticed a covering of dust on the components. I took the hoover to it and an initial inspection could find no glaring problems, such as burnt PCB! I decided to power-up and to my joy the machine whizzed into life. Problem solved!!!!!!!! BTW, this unit is at aprox 10 years old and still goin great!
Posted on Oct 09, 2009
Anonymous
SOURCE: error f61 on a panasonic SK-AK640 CD stereo system
when i turn the power on , it goes off in 3 sec after displaying "f61"
Posted on Mar 01, 2010
Panasonic error f61
If you do not know what an audio output IC is, what would ordering one do for you? And unless you have the know how and special gear there is no freaking way you could ever replace it.
Either have someone repair it for you or go shopping.
Aug 17, 2017 | Audio Players & Recorders
I got panasonic- sa-ak240 stereo system i get F61 on the display then it shuts down to standbye.
F61 is an Error Code......it's basically indicating that something inside the stereo is malfunctioning or broken.
the stereo has gone into Protection mode.....could mean there is Direct Current on one of the output rails....most likely the Power Amplifier IC in your Stereo has gone bad....a new one should solve this problem....you'll need to send it in to Panasonic for replacement of the faulty parts.
Oct 28, 2010 | Panasonic SC-AK240 Shelf System
Error f61
my CD Stereo System SA-AK18 turns off itself displaying f61 error, what does it means? how can I fix it, plz help me
Oct 16, 2010 | Panasonic SC-AK18 CD Shelf System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Error f61 on a panasonic SK-AK640 CD stereo system
May 31, 2009 | Panasonic Audio Players & Recorders
DISPLAY STARTS OK THEN F61 APPEARS THEN STEREO SWITCHES OFF
Probaby needs the output ic. F61 is an output/power error code. But check that the fans turn before trying to replace or taking it in to be fixed. If a fan is not turning you will get F61 too.
Feb 21, 2009 | Panasonic SC-HT441 Theater System
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
