SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
SOURCE: Nikon Coolpix digital camera L18
The red light is probably the focusing beam. I'd guess that your flash is turned off somewhere in your settings. Go through the menu and if you find that it is not turned on there might be a hardware problem. Also, if the flash is set to automatic, it will not work when it thinks there is enough light to take a good pic.
SOURCE: Flashing symbol
This symbol means that the backup battery needs to be changed. The backup battery is a button-type battery, CR1616. It is located under the main battery behind a small square panel. Instructions for changing it are in the manual -- look under "backup battery" in the index.
SOURCE: red hand blinks on screen upper right side. how do
The red hand icon flashing shows that the camera is using a slow shutter speed, and
is a warning to be careful to hold the camera steady.
You could put the flash in auto mode and it will fire when the light is low.
