I have 6 years old Amana Cooling Condensing Unit RCC48A2B at my house. today the outside unit fan won't kick on when compressor is running and the compressor stops after less than 5 mins. The compressor will start again like 15 mins later and around same short time the compressor stop again. I am guessing either Fan motor or relay is dead. The unit system seems to be getting hot due to the fan is not running before compressor shut down.
Be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
