The styles on the PSR9000 are NOT available on the PA50. Any styles of the PSR9000 would only come from the audio generation and outputs of the PSR9000. The PSR9000 would have to be setup to the style independently as that cannot be controlled via MIDI from the PA50 controls.
You have put the keyboard in "Split" mode. In this mode you can assign a different voice for the left hand than the right.
The F# is the standard point to split the keyboard voices.
In the music data bases often a "style" is selected and if you select ACMP accompanyment, when you trigger a chord on the left hand it MAY start the rhythm... If you want an additional voice on the left over what the style is set to, you may have to independently select it.
When you are in style play screen , press record , then select record/edit , it leads you to record screen. on record screen touch upper right hand of the screen (page menu) and select "write style" and this way you can save it whereever you choose. once you are done , on same page menu choose "exit from menu" to get out
