Crafts & Hobbies Logo
Donna Swenson Posted on Nov 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cross stitch pattern for #42733(Mad Bluebird) is incorrect.The legend does not match the pattern. Could I get a new pattern? One example is a diamond shape in the legend is a triangle Thank you.
Jennifer WD
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 15 Answers
  • Posted on Dec 27, 2019
Jennifer WD
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
15
Questions
0
Helped
684
Points
55
When I was considering about making a gift to my cousin, I thought to make it up from cross-stitch pattern, and with images from movie he like, Star Wars. Long story short, here is what I found on the Internet ( website: https://sewhomegrown.com/top-9-star-wars-cross-stitch-and-patterns/ ), on that resource they sell exactly such patterns, which is pretty easy to complete, with different movie scenes.
BennetteZq
Level 1:
Habit-Forming:
  • Contributor 30 Answers
BennetteZq
Contributor
Level 1:
Habit-Forming:
Answers
30
Questions
0
Helped
7151
Points
94
How many layers should there be, when sewing a pattern by cross-stitching ? One or better to do two layers ?
thomas056
Level 1:
Habit-Forming:
Welcome Back:
  • Contributor 18 Answers
thomas056
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
18
Questions
0
Helped
3065
Points
58
Cross stitching patterns are not so easy to produce, as I know. I mean, it's always hard to reproduce images to the pattern.
Jean DeLauche
Level 3:
  • Master 2,911 Answers
  • Posted on Nov 08, 2018
Jean DeLauche
Master
Level 3:
Answers
2911
Questions
Helped
975794
Points
13030
Hello, Donna -
The number 42733 is connected with the Bucilla cross stitch kit for the "Mad Bluebird".
Therefore, you need to contact the Bucilla company regarding the incorrect pattern.
The parent company for Bucilla is Plaid Enterprises. This is the link to the Plaid Enterprises Contact Us page:
https://plaidonline.com/about/contact
Note: Fixya.com has no affiliation with Bucilla, Plaid Enterprises, or any other handicrafts business.
Best wishes.
1 Related Answer
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on Oct 21, 2017
SOURCE: On my Designer Diamond machine, I removed stitch plate to clean out fuzzz. Now it slides backward & breaks the needle. Also, the dog feed aren't high enough. Did i put the stitch plate on incorrectly?
Most likely it is not installed correctly. Check your owner's manual.
I have lost my cross stitch pattern for the Bucilla Cats on a Staircase Christmas stocking. Is there a way to get another pattern ?
There are many Bucilla Cat Cross Stitches available. Here is one of the web sites:
http://www.folkcatart.com/blogs/jen/?p=955
I am knitting an afghan with Taku mi 13 needles.
are you working a pattern or is it a straight stitch like garter or stockinette?
I would make a stitch gauge sample with the smaller needles to see how many stitches per inch.
Figure out how many stitches you will need to match the width of the current piece.
Take that number and subtract the number of stitches you currently have with the size 13 needles. (new stitch count - original stitch count = difference)
Divide the original number of stitches by the difference.
that is how many stitches I would do between increases
Let me use an example:
Say your original work had 75 stitches
From the gauge sample you know you need 100 stitches to make the same width
100-75=25
Now divide 75 by 25=3
Ffter every third stitch, I would put in an increase
that way the increases should work evenly across your piece.
This will be more challenging if you are working a pattern but the goal is to work the increases in as evenly as possible with as little impact as possible on the pattern being knitted. That might mean doing 2 increases every 6 stitches because it fits the pattern better.
good luck.
Name pattern crosses over onto each other
You likely have an imbalance in the Stretch Stitch Balancesewing back and forward.
Make sure you are using Monogramming foot "N"...and check in your Manual for settings for Triple stretch stitch
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
1helpful
2answers
SC 329 code Aficio 550
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
3. Press the “Enter” key.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
dpi).
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
16 Not used
21 Blank Page
2answers
Elna 2002 -
The question was regarding the Elna 2002 not 2007 and it wasn't a problem. I just do not understand how the pattern selection works. Thank you.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
