It says Hi and the button on the far right is green
SOURCE: flashing green button
Where are you located? If you don't want this Sharp 35VX-H2000 anymore, I will take it, even if it's broken. Thanks.
SOURCE: Buttons on left (top slide part) not working -
you change the flex wire. problem will be solved.
SOURCE: I just bought a house
If you open the door, there is usually a label to tell you the model no. on it, so if you use that, you can probably go to the bosch site and find the manual for it there. Your machine sounds like it's similar to the ones that I have located HERE. Simply click on them until you find the one you think is the one you have or close to it, there are two thumbnails, click on the one to the right, showing the buttons, then Enlarge the image, from which you can hover and enlarge it further to get some idea of what those buttons do. Hope this helps
Joe
SOURCE: what is green button located at top right corner of lap top
Hi Shawna
From the owners manual for the 7720, (Page 15) all of the functions of the buttons are listed. Just cut and paste this address into your browser.
ftp://ftp.acer.at/notebook/aspire_7720/manual/Aspire_7720G_7720_EN_McAfee.pdf
Hope this helps you out.
-Steve
