SOURCE: Lint problems in a washing machine.
Most newer machines do not use lint screens. Instead the lint is pumped out during the spin cycle. If there is a build up of lint then I would suspect a restriction in the pump or the inner drum drain holes.
SOURCE: remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
SOURCE: Does the hoover 200m 4.4kg top loading washing
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
SOURCE: dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
SOURCE: My Videocon Fully automatic top
Hi
E9 means the water level sensor is
defective or the pipe connected to it is faulty.Generally error E9 means a
problem with your water pressure sensor. do you have water in the tub? Check
the sensor by pulling the hose attached to the bottom part of the tub and blow
on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
Hello ccparish8 - Base on the model listed above on the post, washer GLWS1339EC does not have a lint filter or any of Frigidaire washing machines. However, if you are referring to replacing the lint filter on a dryer, simply remove the lint filter from the housing and reinstall in the same manner.
Capacity of typical Laundry Basket = 6 kg (dry weight)
Calculation: [(36 cm x 51 cm x 26 cm) / 28317 cubic cm] x 3.5 kg = 5.9 kg
Charlie
