El manual de instrucciones del humidificador Sunbeam SWM2311 est? disponible para su descarga desde la p?gina web Sunbeam. Para descargar el manual del usuario, vaya a www.sunbeam.com/support/manuals y seleccione la opci?n "Humidificadores". Puedes encontrar el manual de instrucciones del Sunbeam SWM2311 en la lista de descargas disponibles
Find your filter for your Sunbeam® humidifier to keep the air in your house comfortable, water treatment tablets offer a light scent to the mist from your humidifier.
Lana, apparently that Model Number may have been discontinued. However, your Owners Manual may be available by calling Sunbeam Appliance @ 888 -264-9669.
You throw it away. If you must, you can disassemble the unit and clean the metal rods that go into the resevoir, sand paper works well for this, they corrode and won't conduct, cleaned off they almost always work, at least for a little while, but two or three cleanings is usually all they will handle before the rods are simply gone, eaten away by corrosion...
if you mean by stone build up, you need a de scaler such as clr from any hardware store. let it soak on the crusty parts overnight the rinse well with water. toothbrush helps too.
