SOURCE: I have an acer aspire
Bottom Line the manual says if the light to not come on when cord is bluged in battery out get a new motherboard. You may also hear a slight ticking like a clock tick.. The Issue is the U58 chip on bottom side of motherboard burns out. sometimes takes out U63, U59 and U64 are same corresponding chip and can fail as well at worst case... Usually just U58..it is a 4812 chip you can get for a few cents...I heard how ever if you replace U58 and think U59 with the U63 chip a 4800IC chip the issue goes away... Trying to confirm... Until I confirm recomend either new mother board or correct U58 chips 4812..mosfet n channel..
SOURCE: My Samsung Galaxy Tab won't turn on, even though battery is full. What's the problem?
hi did you fix your problem?
SOURCE: my tablet is not powering on..it is getting charge
Two most probable problems:
-bad battery
-bad motherboard
If it's still under warranty, get it repaired.
If not, buy a new one
SOURCE: JBL flip only plays while connecting to the mains
Seems the battery has gone bad prematurely. Charging circuits have to be good since the unit works fine off the adapter plugged into the mains.
contact vendor mfg - shoulds be under warranty
