SOURCE: Zebra 140xi II error
If you open the case there is a sensor that detects whether the head is opened or not that is connected to the open and close lever. Sometimes the tab that blocks the sensor when it is closed get out of alignment or comes loose or the sensor is jarred loose. Make sure the tab breaks the beam.
SOURCE: Error conditon ribbon out
if you are not using a ribbon you should configure your printer properties in direct thermal the same with your printer configuration in LCD Panel, if your printer properties is different with the LCD Panel error condition ribbon out will come out to your LCD Panel
SOURCE: Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message.
Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
SOURCE: What does a Polaroid p85igc card printer use for a
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
SOURCE: keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
