SOURCE: My phone has no dial tone.
Check if the cordless works on a normal telephone line,Plug in another instrument to see if you get dial tone,light.
That's it you should know what is causing the problem.
Samir
SOURCE: I can't dial out from my handsets
Monotary suggested the following and it seems to be working for now.
"Disconnect or unplug the power supply (the small black box that is
plugged into the wall outlet) wait for 30 seconds and then plug it in
again. Sometimes the power supply needs to reset itself."
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
SOURCE: can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
