You must use the Master Key to open the safe maually. If you do not have the master key, then the only way to open safe is to break open the control panel.
Mostly the code 0000 is also often used by safe companies as a code breaker. But, make sure that code breaker is used as a safety mechanism is the guest forgets their own code. Make sure if it's of a hotel then all guests should check out whether their own Hotel Safes has a same code breaker before deciding whether to leave their own items in the hotel rooms.You can also use Master Key to open the safe.
Hammer and chisel.....grinder....dynamite
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
SOURCE: how do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking the Fireproof Sentry Safe open.
SOURCE: i can't open my safe.
Sorry, but you can't, That's why it's called a "safe".
If you lose the keys or the combination then the safe must be cut or drilled open. Some specialist locksmiths may be able to pick the lock or crack the combination, but it usually takes so long and costs so much that destructive entry proves to be cheaper. Many safes also have unpickable locks and uncrackable combinations anyway.
SOURCE: Hi, I have a Brink's
Brinks will not help you with this, but you should be able to get into the safe if you call a locksmith. Brinks use a really cheap lock tumbler on models similar to yours and it's easy to pick for a skilled locksmith. So easy, in fact, that you really won't want to use that safe again as it's really an unsafe...
You can watch an example of how easy it is by clicking here.
SOURCE: How to creeate a new combination for a sentry 1310 valueguard saf
Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
