Watches Logo
Posted on Nov 04, 2018
How do i know ifmy wavecepter watch is set to automatically switch to dst
2 Related Answers
Anonymous
  • 6 Answers
  • Posted on Dec 26, 2008
SOURCE: G-shock Wavecepter is 1 hour to fast
(I posted this solution elsewhere but it should help you as well.)
Firstly, the manual that comes with these watches is absolute garbage,which is a stark contrast from the watches themselves. ( I love casiowatches - high value)
The good news is that Casio DID make a good manual for these wavecptor watches. If you go to this url
http://world.casio.com/wat/download/en/manual/
you will be at a spot where you can type in your 4 digit module numberand get a great document that tells you how to operate your unit andsome of how it works. (Adobe Acrobat - PDF file)
You should be able to hold in the "Adjust" button until the time zone starts flashing and push "Time Memo" and/or "Recieve" buttons until you are in the right time zone. Push "Adjust" again and your are done. The Manual above was very useful for me.
Hope that helps. :-)
Anonymous
  • Posted on Feb 15, 2013
SOURCE: casio user guide for module no. 3353
everything works except alarm any ideas battery v good
1helpful
How can I switch radio-controlled watch to DST?
Yes, if it's an " atomic clock " it should automatically change to the correct time although this may take a while, like 3 to 4 hours.
Mar 29, 2016 • Watches
tip
How to adjust your Skyhawk for Daylight Savings Time (DST) *aka How to get UTC...
How to adjust your Skyhawk for Daylight Savings Time (DST) *aka How to get UTC to reflect the correct time when your local time is set*
According to Citizen's website FAQ, their watches cannot determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. If you are on the winter side of the time change (fall back), you'll have to go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) and in the spring change all of the appropriate timezones back to ON (for summer time). Disappointing, I know... for an otherwise great watch this would be my one complaint.
on Nov 17, 2011 • Citizen Watches
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 • Watches
DST on MTG900
The MTG-900 supports automatic DST which can be activated in the time setting mode.  However, the ROM in the MTG-900 dates from before Congress (in their infinite ability to make mistakes) modified the DST schedule, so, instead of switching at the beginning of April and the end of October (as currently specified), it switches at the end of April and the beginning of October (as previously specified).
I do not believe that there is a way to change the DST scheduling or manually turn DST on or off.  I've resorted to changing the time zone manually and turning off the DST feature.  IOW, I set the timezone to Pacific (LAX) during PST, and, to Mountain (DEN) during PDT.
4helpful
3answers
Echo drive skyhawk,My watch's time zone is always one hour behind
You posted this in January, which is not during daylight savings time. The SMT setting doesn't turn on automatic DST switching for a particular timezone; rather, it is a manual override to adjust timezones to DST when it is actually active. There is no automatic DST adjustment for this watch (according to their FAQ). Turn SMT to OF for all timezones during winter months, and ON for applicable timezones during SuMmer Time (SMT).
2answers
How do I get the wave ceptor to come on ?Casio-2688
If DST is set to AUTO,time (DST ON-DST OFF) is corrected automatically when the watch is synchronized.
Synchronization period (Radiocontrol) from 00:00 until 06:00.
If you live in an area where atomic signal cannot be reached by the watch,you have to change DST-NORMAL and vv,manually,by going to WT (World Time) function and when your city (or the closest big one) appears on the display,press and keep pressed for 1-2sec the SET button.
DST mark will appear or disappear,accordingly.
Time zone
You don't need to set the watch back an hour.  You just need to turn off the automatic DST adjustment.
Hold ADJUST for several seconds.  Then, when DEN starts flashing (or whatever timezone you are set to), hit MODE The display will change to DST flashing at the top and on or auto flashing at the bottom. Click TIME/MEMO or RECEIVE to change on->auto->off.  Once off is flashing at the bottom, hit ADJUST twice and you will be out of DST mode and everything should be fine.
2answers
Reset my G Shock watch
try http://forums.watchuseek.com/forumdisplay.php?f=17
seems pretty extensive.
you either need to set your time manually if you are not automatically receiving the atomic signal. if you are receiving the signal, then either you are not in auto DST mode or your home city is set incorrectly.
Nov 08, 2007 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
