The Spy Net Watch was produced at least as early as 2010. Its software struggles with Windows 10 compatibility. You might try attaching the cable to a system which has Windows 7 and see what happens. I am including some links to manuals. Here is a review with some interesting points about the watch:
https://www.thebrickcastle.com/2016/12/spy-net-touch-video-watch-and-eyeclops.html
https://www.gadgetsspy.com/spy-watch-instructions-how-to-use/
The problem is a worn out battery because it is not charging while it is connected to the computer's USB port.
The recharageable battery needs replacing.
SOURCE: When charging the spy net
Did you push the left button (has a green minus sign) at the bottom left of the video display? The battery indicator will be on the upper right.
SOURCE: Jakks spytech watch only
Same problem. But I am able to set the location, time and date while usb connected. As soon as I pull it out, total failure. Even tried the RESET button on back, but nothing works.
Anybody... anybody?
I had the same problem, too. What I should I do now?
Same I think it might just be cause it’s too old but I connected mine to my pc and got the videos off it
