The Memory Cards in these models are limited in their capacity to hold a stitch file. Newer models use a USB port that can keep a larger file on a jump drive.
Think of it as a Computer with a Needle and note the capacity of your memory card vs. the file size of the design in mb. remembering that 1 Kilobyte (Kb) equals 1,000 Megabytes (Mb).
Hope this helps!
SOURCE: 180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
SOURCE: bernina deco 600
Sorry to inform you but your machine only sews 4" x 4" . The arm on the machine can only move 4 inches up and down and 4 inches left and right.
The size of the hoop does not affect this. If you have a multi position hoop you can sew multi 4 x 4 areas without re hooping.
SOURCE: Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
SOURCE: pr600 shunts over on big designs
You can try to calibrate the hoops by having the machine turned off and the largest hoop and smallest hoop ready hold down the start/stop button and the needle theader button and turn the machine on while holding those in, you should get a different screen that say a/d test in the upper left corner, put the largest hoop on the machine being shure the screws are tight and hit the l button on the upper right side the numbers next to the button will change, then put the smallest hoop on and hit the ss button once the thats done turn off the machine and on again and it will start normally and try your designs again if that doesnt work take it to a brother service center/ dealer and tell them to check your x-axis position
SOURCE: bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
