SOURCE: Dacor Gas wall oven
is there tension on the door at the point where it doesnt seal,is the spring broken/missing,when the door opens and closes is there enough travel from point a to point b inside the cabinet on both sides of the hinge area, is the sping loaded mechanism damaged .
SOURCE: Looking for hinges for a Dacor oven
http://www.repairclinic.com/SmartSearch/smartsearch.aspx they they have some here
SOURCE: dacor touchpad
HI, this is a Element relay
circuit failure. this relay is a separate PCB board with attached relays.
this relay board will need to be replaced.
CLICK HERE TO ORDER
SOURCE: I need to know how to change the gaskets in my
Hi, to change the gasket on your Dacor ECS230 oven, you have to follow the instruction on the page 8-20 of the oven service manual which is available on this LINK.................
SOURCE: Dacor Oven model # CPS127 - part # 13158B - discontinued. How to find
More than likely your not going to be able to find a part once its been discontinued, especially if its been that way for a while, but there is an alternative though. There are companies that specialize in rebuilding control boards, etc that have been discontinued and are no longer available. I would contact a company like appliance parts depot or another major distributor because they will have the numbers you'll need to contact those companies, but remember, whatever the cost of the part was is nothing compared to the cost they charge to remake the part.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
