Sewing Machines Logo
Leon Raubenheimer Posted on Nov 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a elna pro 5 dc lock why does the no 4 thread not stitching when done it just pulls out I gave not got a manual please assist thank you so much
Rene Williams
Level 2:
Habit-Forming:
  • Expert 93 Answers
  • Posted on Nov 03, 2018
Rene Williams
Expert
Level 2:
Habit-Forming:
Answers
93
Questions
Helped
27581
Points
267
The 5-thread model has an 'extra' lower looper. Probably something in the threading path is off and the only way to correct this is to pull all of the threads out and rethread them in reverse order: 5-4-3 and then the needles.
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Feb 17, 2008
SOURCE: Elan Pro 5 DC
Try contacting Elna directly, or find your nearest agent thru their website, if in USA ....here
having this photo should help trace a part number if you can get onto an Elna service technician, if it were Janome, I could look up our references, so it should be straightforward.
Anonymous
  • Posted on Jan 26, 2009
SOURCE: Elna Pro 5 DC
i solved my own problem, and hopefully yours too, Cindy:
i found a manual on eBay, rom a seller in the US. including shipping to Australia it cost me about US$45. just search for "manual elna pro 5 dc"... he has got stacks of manuals for all sorts of machines.
hope this helps other people too :)
cheers,
L
Anonymous
  • 6 Answers
  • Posted on May 05, 2009
SOURCE: REX blind hem how to lock the stitch
When I purchased my blindstitch machine, I was also told to kind of snap the fabric as you pulled it our of the machine. Like you, I found that to be a little risky. Sometimes I'd just unravel what I'd sewn. I have found the most dependable thing to do is: Before removing the fabric from the machine, snip the thread between the fingers of the looper as it approaches the needle. If the loop is broken, the chain stitch will not pull out. If you cut the loop as it approaches the needle, you will get a bit longer tail so the needle doesn't come unthreaded on the next run. If you find you need a bit longer thread tail, you can pull a bit on that loop before cutting. As long as the needle has passed through the loop on the previous stitch, you'll be fine.
Anonymous
  • 208 Answers
  • Posted on Jun 29, 2009
SOURCE: I need an Elna Pro 5 DC serger machine Owner's Manual
The original manual is out of print and all that is available now is photocopies and they cost about $15. Let me know if you still need it and your zip code so that I would know how much postage would be.
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 30, 2011
SOURCE: I need a user manual for the Elna Pro 5 DC serger machine
Hello, merry
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about Sewing Machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/sewing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
2helpful
Elna lock pro dc 5 upper looper release lever won't move to the left
If the upper looper release lever on your Elna Lock Pro DC 5 is not moving to the left, it may be jammed or stuck. Here are some steps you can try to fix the issue:
  1. Ensure that the needle bar is in the lowest position, as you have already done.
  2. Turn off the machine and unplug it from the power source.
  3. Remove the needle plate and check for any thread or debris that may be obstructing the lever.
  4. Use a small brush or vacuum to remove any debris or lint from the area.
  5. Apply a drop of oil to the lever mechanism and gently move it back and forth to see if it will release.
  6. If the lever is still stuck, try gently tapping it with a small hammer or rubber mallet to loosen any debris or rust that may be causing the issue.
If none of these steps work, it may be necessary to take your machine to a professional for repair or servicing.
What are the correct settings for basteing on an elna excellence 730
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
2helpful
2answers
I nead a manual for a elna special ? please
try this link http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna_EC_ZZ_SP_ST_SU_manual.pdf
there is a sewing guide available too, the SP would have less stitch functions than the SU - they did combined manuals for this range I think.
Good sturdy Swiss made machine, these were used in school classrooms for many years in NZ.
1helpful
I need a manual for an Elna Special machine. I am not sure of how to thread the machine properly and I don't know what one of the dials on the front of the machine does.
There is also a Yahoo group for Heirloom Elna owners which this model is.
You can find threading diagrams and manuals at www.sewusa.com. the supermatic will be closest to your Special. This webpage has images of threading the bobbin; all Swiss made Elna's have this wonderful top loading bobbin system and they are great. Important: use Elna bobbins, they have holes on the TOP ONLY. When you wind the bobbin, ensure the thread winds evenly by nudging the thread with your finger tip, keep the thread under tension as it winds by placing the handle of your scissors onto the top of the thread reel. Cut the thread, then place the bobbin into the bobbin case, holes upwards. The bobbin will turn anticlockwise as you pull thread from it. Follow the directions from the threading diagram, you need to "click" the thread into the tension spring. Now thread the top thread through the marked locations in the diagram. Hold the end of the thread as it comes from the needle and manually turn the flywheel to lower the needle down and up once to catch the bottom thread and bring it up to the needle plate.
ALWAYS hold both the two threads at the back of the needle plate when you start sewing, really important. I tally_girl.jpg You will have a knob with numbers going from -4 to 4, this is your stitch length dial. The negative numbers are "Reverse" normal stitch length is 2.5. The white knob is stitch width when the needle swings from side to side. Straight stitch would be zero, and then higher numbers for zig zag etc. The little wheel gives you different needle positions. And the metal slide at top of case is the reverse lever.
Hope this helps you a little. Early Elnas are all very similar and wonderful machines to use.
I have an elna overlock Pro 5DC, which I bought new years ago. The dealer went out of business, and with her the repairman who knew Elnas. When mine developed a problem, I had it serviced by an all-brand...
If you google elna overlock pro 5dc, I found this site and you can download your manual for $10, hopefully it will help you.http://www.tradebit.com/filedetail.php/30251842-elna-pro-5-dcde-sewing-machine-owner
It is so frustrating to have a great machine and no one can help you. Good luck
7helpful
4answers
I have a Baby Lock BL4-736D serger. I need the
orange-(5-7)
yellow-(4-6)
green-(2-4)
blue-(2-4)
medium weight, 4 thread
Elna pro dc 5 stitch width lever
Hi Dawn,
That machine is a Hosea Serger right?
I looked at some specs but I can't find that part you have described. Is it on the front panal?
Sergers are tricky, you might want to have a someone look at it make sure it is balanced. I'm gonna look into a couple more options for you in the mean time.
Bonnie
3answers
Elna Pro 5 DC
Yes I have one, can you tell me where can I get parts for my Elna Pro 5 DC?
Nov 01, 2008 • Elna 1010
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
