SOURCE: FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
SOURCE: lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
SOURCE: re set rangemaster oven
u first have to set the correct time of day. press and hold the (+) and (-) untill u put in the corerect time. dont forget its a 24 hr clock.if u make a mistake or press the wrong button.turn off the power supply for a minute or two then start again.
to enter the start time of your cooking, press and hold the button to the right of the bell symbol button (second on the left) and the + button at thee same time, untill your required 'cook time' shows, then press and hold the 3rd button to the left, ( the empty pot symbol) at the same time press (+) or (-) untill your required 'stop time' shows.
AUTO will show on the display. set the oven to the required temperature. when your cooking is finished the beeber will sound.
TURN THE OVEN KNOB TO 0 FIRST. then press the hand symbol button once to stop the beeb, press again to return to manual cooking.hope this helps!
SOURCE: Oven tripping
Was the oven tripping the the fuse before the element was replaced,also did you take the oven out to do element because the element can be done with cooker in place it may be that you pulled out the connections block at rear of unit and it is touching body.If tripping before replacement the fault could be any where on the oven.You will have to check it through.
