Question about Generac Electrical Supplies
Generac 01815 standby generator firing the starter every 20 seconds although the motor is already running.
Update: I pulled the solenoid signal wire after the generator started to prevent the starter from running again. Generator ran for a couple of minutes before shutting down and throwing the "Engine fail to start" code. Update 2: I pulled the panel to expose the CMA board. I'm getting just under 3VAC at the CMA connector when the generator is running. It drops off to 0V when the generator stops.
6ya staff
SOURCE:
John McKinney
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: No voltage output
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
Posted on May 12, 2009
Anonymous
  • 52 Answers
SOURCE: Have to attach a red cable to a terminal on the
Some gensets have a reverse generator that actualy rotates the motor until running then switches back and produces power. But the starter could be in the front of the engine looking like a altrnator or some such device. good luck..
Posted on Aug 30, 2009
Bob Janelli
  • 26 Answers
SOURCE: Generac 43903 standby Generator overspeed indicator on starting
I have a generator that did the same thing. It would start and then stop within a few seconds. The more expensive generators have an oil level safety switch to prevent the engine from burning up. There is usually a wire connecting to the switch on the outside of the engine near the oil fill hole. Remove this wire and try to start the generator. If it runs without a problem then it is the switch. You need to remove the switch and take it apart carefully and clean it. There is a small float inside the assembly. When the oil runs low the float allows the switch to short to ground which kills the spark to the spark plug. Hope that helps.
Bob Janelli
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Posted on Oct 01, 2009
Testimonial: "This is good information in the event that the low oil switch is part of the problem."
Anonymous
  • 25 Answers
SOURCE: generac home generator does not start
is this unit diesel or gas? If its gas driven, the carburetor needs to be removed and cleaned out. Also make sure your gas is fresh. If not drain fuel tank, remove carb, clean out, re-assemble & test. Check fuel filter, oil level.
Posted on Feb 11, 2010
I have a xp10000e duromax generator.
Hi. If the ignition switch and the wiring from the ignition switch to the starter are good. Then I would look at the starter solenoid. The solenoid is normally open and only closes when the ignition switch is turned to the start position. Remove the "Trigger" wire from the starter, reattach the battery cables and use a test light to confirm. Good luck.
Aug 25, 2018 | Electrical Supplies
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
2003 s-10 changed motor, now won't start. you can
CODE P1637 - GENERATOR L TERMINAL CIRCUIT MALFUNCTION CONDITIONS. CODE P1638 - GENERATOR F TERMINAL CIRCUIT MALFUNCTION CONDITIONS. POSSIBLE CAUSES FAULTY GENERATOR WHICH IS ALTERNATOR.CHECK GENERATOR POWER FEED WIRES AND CHECK GENERATOR VOLTAGE REGULATOR WIRES FOR LOOSENESS AND DAMAGE. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS. IF BATTERY WEAK DUE BAD GENERATOR VECHICLE WONT START.
Sep 23, 2011 | 2003 Chevrolet S-10
Honda ES6500 blows 15amp fuse as soon as the key is turned to "ON" tested starter with a jumper wire, works fine. Took the control box apart found nothing unusual. Removed ignition switch found...
hi
I think the problem is on when the key is turn to rotate and to engage the starter motor and it at this point that the cable curring the current on to the starter motor it then the fuse gets blown , in my opinion this cable is shortening across the chassis causing the fuse to blow, or when it get to the starter solenoid a faulty solenoid absorbs accessed electric current causing the fuse to blow
Jan 16, 2011 | Honda Electrical Supplies
Do you have starter wiring instructions
Starter wiring on these are pretty easy, here are the following steps...
First, disconnect the battery first before attempting any wiring repair or replacement of electrical system components. I assume the old starter has been removed, so here are the steps to wiring on the new one.
First trace the generator wire (generally a 10 or 12 guage) wire from the generator. this wire along with your positive terminal cable from the battery and a wire which runs to the "light" pull switch all connect to the left side of the starter solenoid which i on top of the starter housing. This solenoid has "2" sides. With the bracket at the rear (towards passenger seat) the left side holds the three wires discussed above. The other side should be connected to the starter itself that has a bolt on the outside. This is a ground wire. If your starter didn't come with a new start solenoid, then this ground wire from the starter will go on the right side of the solenoid. Lastly, there will be a place to mount another wire to the top of the solenoid housing. This wire will run to the push button start near the gear shift on transmission housing. After all these connection have been completed, then reattach wires to the battery, and the tractor should start. If the tractor has been stored a while, may want to drain gas and replace with new for best start, and also check all the fluids such as water, oil, and the trans/pto/and hydraulic lift fluids.
Let me know if you need anything else!
Chip
Apr 03, 2010 | Ford 8N Tractor
I am trying to connect battery terminals to my EQT generator.
Connect the black lead (negative) to the frame of the generator.
Connect the red lead (positive) to the big post on the starter solenoid. There are 2 big post terminals on the solenoid. Connect the battery positive lead to the one that DOES NOT go to the starter motor.
Dec 26, 2009 | Honda Mmd 5000 Watt Electric Start...
Onan 4kw Emerald I generator will not crank
The gen. is not the problem, the engine start circuit is not functioning. You need to look at the starter solenoid and starter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 01, 2009 | Electronics - Others
Generator will not start
Is the oil sump full? Has it been run with out oil? You can do an amp draw test on the starter. Should be 60 amps or so. Can you roll the engine by hand? If engine turns free pull the starter out and bench test it with jumper cables. Positive cable to cable lug and negative cable on the starter case. Hang on to it, lots of torque. If the stater turns slow or gets hot it is probably bad.
Mar 25, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
I cannot crank my coleman powermate generator.
If the engine will not crank-if it has an electric start, first check the battery and connections to the starter and ground. If the battery is good and the connections are clean and tight, then I would check the ignition switch. If it clicks once when the key is turned to the start position, check for a seized crankshaft (see below) If it does not click, then it could be the starter, solenoid, or the ignition switch. If it has a manual pull start, and it will not pull, check to make sure the crankshaft can turn freely and if not, disconnect the pull starter and check it again-if it turns freely the rope start mechanism is hung up-it must be freed up before you can pull start it. If the crankshaft will not turn at all you probably have a serious problem that will require a major teardown.
Jan 29, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
122 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
