There might be batteries for the dashboard display but the motor is mains powered. I suggest you read the instruction manual. There is quite a lot about the machine on the internet. Try a search, try the link below.
https://www.horizonfitness.com/horizon-t101-treadmill
SOURCE: My Horizon T101 treadmill has
no there isn't, in fact the key is a magnet plate mechanism but you should try attacking the problem by first checking the fuse which is located at the head end of the machine. If that doesn't work then remove the motor cover and get a qualified electrician/technician to check the circuit board for any possible faults.
hope this helps
SOURCE: where can I buy motor control board for horizon treadmill T101
just run in the open air, it's much better to experience real life
