SOURCE: Kirby G 6 but it only blows air out, no suction. Also how do you detach the cloth bag to wash it?
I have the solution for the cloth bag laundering process...
Here is a link to my guide for cleaning the Kirby cloth bag...
http://reviews.ebay.com/DEODORIZING-CLEA...
It should be helpful. :0)
The Tech Drive problem SHOULD be able to be fixed easily and fairly cheaply by a vac shop or Kirby distributor. There is an adjustment that needs to be made, but it shouldn't require purchasing any parts.
Marci
SOURCE: Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
SOURCE: I need to install a mini emptor on a Heritage II Kirby
I actually figured this out on my own. Just removed the rubber out seal between the bad and em-tor, then used a screw driver to gently pry the bag out of it's grove. The wire part of the hose actually unscrews from the em-tor. Reverse the process to install the new one. Gotta love Kirby engineering.
SOURCE: Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
SOURCE: looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
