SOURCE: User manual for shoprider madrid mobility scooter
Go to the Shoprider website and look for the scooter. It might have a different model name than the one you own. Get the name and click on the user manuals for the model that resembles yours (PDF file) and print.
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
SOURCE: tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
SOURCE: Hi I have a shoprider cadiz .. when i try using
your throttle pot needs replacing. your thumb lever attaches to the throttle pot.
Testimonial: "Wonderful information Thank you ..before i read your answer i sprayed the throttle pot as you call it with switch cleaner Been great since .. "
SOURCE: My Pride Legend 3 wheel scooter will not go
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
