Garden Logo
J
Judy Pike Posted on Oct 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel ratio mix for Yukon Brush cutter model no. ZJBC305B
Nick Olsen
Level 2:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 196 Answers
  • Posted on Nov 25, 2018
Nick Olsen
Expert
Level 2:
Teacher:
Answers
196
Questions
Helped
92425
Points
281
2 Related Answers
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Oct 11, 2012
SOURCE: What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
plink_plonk
Plink-plonk
  • 1807 Answers
  • Posted on Apr 16, 2016
SOURCE: Fuel ratio for homelite 40cc brush cutter
50:1
100ml of 2stroke oil in 5L of petrol.
What is the oil to fuel ratio for a cub cadet trimer/brush cutter?
The exact mix ratio for Cub Cadet trimmers varies, depending upon the exact model. Cub Cadet's ST 228 2-cycle trimmer model uses a mix of 2.6 fluid ounces of 2-cycle oil blended with 1 gallon of unleaded gasoline or a 50-to-1 ratio. This equates to 20 milliliters of 2-cycle oil to 1 liter of gas. The Cub Cadet BC 210, on the other hand, requires a mix ratio of 40 to 1, or 3.2 fluid ounces of 2-cycle engine oil to 1 gallon of unleaded gasoline
50:1
1helpful
Brush cutter
Drain your Gas out and mix up fresh Gas Mix and then it should run, Your old gas is only good for about 4-6 weeks because of the ethanol in it., you might have to possibly clean your carb. and change fuel filter, but would try fresh mix gas first
May 24, 2013 • Garden
3helpful
Hi marius65..
Please rate me
Bud
2answers
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 • Garden
5helpful
What is the ratio of gas and oil mix for a ryobi 31cc trimmer
just use about 3 to 4 ounces of 2 cycle oil per gallon and you should be fine. a little extra lubrication wont hurt it
Top Garden Experts
Jay Finke
Jay Finke
john h
