E21 Problems with water drain in wash phase
Check the drain hose and pipe for blockages.Replace the component if necessary.Good luck with the machine.Please do post comments and results.
SOURCE: my zanussi washer dryer wjs 1397 w drum is not turning
It is most likely that the drive belt is broken and needs repalcing, If you remove the rear panel it will be obvious if it has broken *** there will be a lrge flywheel attached to the drum and no drive belt going to the motor, near the bottom of the machine. These are easy to obtain from any domestic appliance spares store or mail order. They are also very easy to fit.If the drive belt is in place and is reasonably tight (taught) then you may have an issue with the motor. clutch or brake.
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door
seal:
For all Free appliance repair videos visit our VIDEO
TUTORIALS
Disconnect all power to the machine first!!
1 Locate the
outer clamp band securing the seal to the door rim on the washing machine and
examine it carefully for holes or tears. Many can be prised off with a
flat-bladed screwdriver they have a spring system holding them, but some have a
tensioning arrangement that has to be loosened.
2 After
removing the outer
clamp band, locate the inner one securing the seal to the drum and
establish how this is secured. It may be necessary to loosen a clip, or you may
be able to prise the band off with a flat-bladed screwdriver. Some are like
very large Jubilee clips that you have to undo usually from the top.
3 Once the
clamp bands have been removed, use both hands to pull the seal away from the
inner drum rim. Some machines have a water spout holes that will have to be lined
up. Others have a drain holes.
4 Rubbing a
drop of washing up liquid into the groove on the door
seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing
machine door seal should be fitted by locating the drain holes at the bottom
of the seal first then push it on with both hands working opposite directions
towards the top. This is quite hard if you have never done it before.
6 refit the
inner band remembering this must be tensioned correctly for it to be water
tight.
7 now fit the
outer band and the test the machine for any leaks,
All washing machine spares featured in this article are
available at apart4u with more video
help in our tutorial
section.
Information provided is a guide only. aPart4u accepts no liability for any
problems occurring whilst attempting any advice shown. If in any doubt about
fixing your appliance, always contact a qualified repairer.
SOURCE: I am getting a Code E20 on Zanussi Washer Dryer
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
