SOURCE: Condenser Dryer turns but no heat
Check with multi-meter for power on the heating element's tags (115/220V). If it does get power,you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
SOURCE: How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
SOURCE: kenwood R-600 amateur radio receiver tuning problem
If its like the older yeasu's, they had a black and white veined disc on the back with opto electronics, dust used to get in and obscure the sensors...
Worth a look.
SOURCE: dialing presets
Hi John, you posted this a LONG time ago.. but I will add a sollution incase anyone needs to find out in future..
to add a number (i.e 01234567890)
1. Lift the handset
2. Press the 'STORE' key, then enter 01234567890
(the number will not be physically dialed - rather, the telephone is memorising it internally)
Press the 'STORE' key again after you enter the number
then select the button you wish to locate it to.
i.e : 'STORE' » enter telephone no. » 'STORE' » Press desired memory button..
Hope this helps
Kevin (In Dublin, Ireland)
SOURCE: we have no dial tone on our phones and need a
you will find the user manual at this location
http://www.2instructions.com/search.php?cmarque=PHILIPS&modele=CD%20365%20TRIO
Please dont forget to rate me as this will help me to help others.
If you require any further assistanc please feel free to ask me.
Reb
