Question about Technics Audio Players & Recorders
Technics su x901 Output sound cable to CD does not connect securely - red light goes on and off. New cable but still problem persists.
It seems like a bad connection inside the amplifier - how to check this?
6ya staff
SOURCE:
Anonymous
  • 682 Answers
SOURCE: technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Posted on Jul 16, 2008
micmor100
Morne Olivier
  • 257 Answers
SOURCE: Technics SL1500 will not connect to new Sony STR-DH100 receiver
Unfortunately, a turntable runs on a different frequency, and if there is no button at the back of your receiver to change the frequency setting on that channel, it wont give you any sound. the best bet is to go to your music store and purchase a small DJ mixer. connect that to your receiver, and run the turntable through your mixer. the mixer will have the neccesary flip switches and "ground" connections
Posted on May 06, 2009
Anonymous
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
technical114
Stelios
  • 1851 Answers
SOURCE: i have a technics su-v660 integrated amplifier.the
Unplug the power, open the case and try to locate some electrolytic capasitors is series with the audio at the channel with the problem. One of them must be blown.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 11, 2010
Marcel
SOURCE: TECHNICS SU-V50
Goodevening,I<m looking for an current Drive for mt amplifier technics SU-V50.
Posted on May 27, 2013
Technics su x901 I can't get sound from two speakers. Speakers are allright
Hi if u have checked everything out
the only thing left is to replace the
IC.amplifier chip which is bolted to the large silver heat sink...when u replace make sure u put some new heat sink compound on the IC ..if u don't know how to use a soldering iron properly don't attempt to do it u can easily destroy the new IC chip with heat .cheers
img_20180812_210420-atdntc5iu4vb0rprfo4qjnnn-2-0.jpgimg_20180812_210420-atdntc5iu4vb0rprfo4qjnnn-2-2.jpg
Aug 12, 2018 | Technics Audio Players & Recorders
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
I have a technics su-v660 integrated amplifier.the voltage selector light comes on but the current drive light is intermittent .when the red drive light is on it works PERFECTLY but only for 5 minutes then...
Check for dry solder joints especially on the main power output transistor.
A blown power transistor will stop the 'Current Drive' from engaging so if the problem you have is intermittent then it is most likely dry solder joints.
Hope this helps.
Mar 17, 2010 | Audio Players & Recorders
Hi my technics su-x120 inputs not working!
get audio cord or use yellow red white in for audio sound
Dec 05, 2009 | Audio Players & Recorders
Digital optical output for technics 5.1 surround sound receiver
Sep 16, 2009 | Technics SA-DX930 Receiver
Blinking light on front of amplifier Technics SU-V10X
Blingking Light usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Jan 30, 2009 | Technics Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
Jun 24, 2008 | Audio Players & Recorders
57 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
