RCA OPAL M4001 MP3 Player Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA Opal M4204-A stuck on "initializing..." How do I correct this ?
Anonymous
Level 2:
Novelist:
  • Expert 166 Answers
  • Posted on Aug 04, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
166
Questions
0
Helped
55538
Points
427
You can try fomatting it.to do so plug it and open my computer.go to the drive of the mp3 and right click it.in the sub menu click format(to foramt it you have to be administrator)(also be sure backup all of your music,videos,pictures,and anything that you want to save.)
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
571
Points
I had the same problem. I just held power button down for about 20 sec. Then turned back on and worked fine.
What happened to my Opal M4204 Player, I could not use it anymore cause it is always on initializing only.. Please help me.. Thanks
You should repair your device. This link will help you:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/9202/~/firmware-update-for-rca-m4204,-mc4204,-m4204p-mp3-player
This is a customer support site and you will find all information you need to get back your player again.
Thanks,
gylacz
My RCA Opal was fully charged. When I powered it on. It. Says its initial. izing that's it what do I do ? It would be great if I had a telephone # so I could so I could speak with a tech live.
if its stuck on initialize you need to re-set it. there should be a tiny pin hole that you can press with a toothpick/safetypin or a sewing needle
My player stays on the opal initializing screen
ele nao ta ligando so assim initializing
Initalizing
RCA M4204 MP3 Player initalizing Answer mp3 is stuck on initializing?
My mp3 player opal m4204 - a doesn't work anymore!!! stuck on the initializing screem which says ''low battery'' ''shutting down'' what can I do?? my computer didnt recognie it either HELP!!!
Mines doing the same thing i can suggest trying it on another computer. If that works then you need to install the lastest update of firmware on your mp3. Tell me if that works for you.
How to i play videos on a RCA M4204
Log onto the RCA website and download the RCA SMV Video Converter. The Opal only plays videos that are in one specific format. This converter will put your videos into that exact format (see Resources below).
Install the RCA SMV Video Converter once you have downloaded the software.
Open the RCA SMV Video Converter software to begin putting videos onto your RCA Opal.
Connect the RCA Opal to your computer using the USB chord that came with the device.
Wait until the RCA SMV Video Converter software reads that the device has been connected. You will know this when the bottom of the software screen reads “Player Detected: Opal 1GB 2GB.”
Select the “Browse” option to find any videos that are on your computer which you wish to add to the RCA Opal.
Click the box next to “Transfer output files to OPAL 1GB 2GB after conversion is complete” after you have selected all of the videos which you wish to convert. This will automatically add the videos to your RCA Opal after they have been converted.
Click the “Convert” box after you have selected all of the videos. The videos will automatically begin to convert to the correct format. Once they have been converted, your videos will automatically upload to your RCA Opal.
RCA Opal M4204 screen problems..
well you could try to restart the opal
Opal m4204 turning itself off
Turn on the mp4 play goto settings. Scroll down to power saver and turn it off.
1helpful
2answers
Rca m4204-a initializing until battery dies
I have to same problem it keeps doing it over and over again
3helpful
2answers
Rca m4204-a
Fatal error on RCA Opal:
What do I do if I experience a Fatal Error? How Do I reset my Opal?
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player. If this does not work, I suggest that you reformat the player by using the Windows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device.
Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
RCA Opal - Stuck on "Initializing"
Go to this website to reload the firmware:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1415&p_created=1202430585&p_sid=CwOaz8ej&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTIsMTImcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1pbml0aWFsaXppbmc*&p_li=&p_topview=1
Note: websites are subject to change - if you go to http://www.rcaaudiovideo.com and go to the page for the RCA Opal m series, you can also find the firmware reload on that page.
-Tha Mp3 Doctor
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
