If it is the same Outward Bound, might try contacting them using web site:
https://www.outwardbound.org/gear-store/
Try search on Google.com and Ebay.com
Also, Etsy.com often has used items for sale that are over 10 years old.
SOURCE: setting alarm on watch
You should be able to download the manual for your watch at the site below. If you cannot, contact Timex for support.
http://assets.timex.com/manuals/index.html
Jerry G.
SOURCE: Indiglo has died on over 10 of my Timex watches
If they have replaced that many watches in that short period, I'm going to say that it isn't the watch.
Timex watches are equipped with some of the largest and strongest batteries in the industry and have some of the best reserve potentials. Have you ever replaced a battery and did it make a difference?
Do you use a magnetic bracelet or work around strong magnetic fields - either of which can deplete a battery - generally in about four months? If so, put the bracelet and watch on opposite wrists. This is usually not a problem with a digital watch. I suspect it's because the magnet makes the analog movement work harder and depletes the battery faster.
And some people just can't wear a certain watch. My mother is one of them. There is something electrical or magnetic about my mother that keeps her from wearing a mechanical watch. When I was a kid, the only watch she could wear was a green plastic Davy Crockett watch.
And 50 years ago, my left handed brother gave me his hand-me-down Timex when it quit working for him. I put it on my left wrist and got several more years of wear out of the watch. I think he wore out the movement on one side wearing it on his right wrist and I wore out the jewels on the other side wearing it on my left wrist.
SOURCE: I have the timex 1440 wr50m radio control watch.
Good day Sir, This model (WR50M) has four buttons, from left to right, top to bottom:
1) Set; 2) Start/Stop; 3) Mode; and 4) Indiglo.
To set or change the time:
1.Press and hold Set and Start/Stop simultaneously; the seconds will start
to blink
2.Release both buttons
Use Mode button to toggle through to Hours, Minutes, etc.
3.When desired number (such as Hours/Minutes) starts to blink, use
Start/Stop button to change number
4.When done, hit Set
have a nice day.
SOURCE: I have a Timex Ironman
This one is quite simple. Just remove the watch back with a watch case knife and flick out the old cell then carefully press in the new one (VERY carefully as the movement is made of plastic). fit the back exactly the way it came off (note the direction of the writing).
