Heating & Cooling Logo
Charles Parker Posted on Oct 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Coleman eb15b and somebody had put a different thermostat on there I got yellow red green and white wire Coming Out of the Furnace but where are the the Box
Bill Long
Level 3:
Guru:
  • Coleman Master 606 Answers
  • Posted on Mar 19, 2019
Bill Long
Coleman Master
Level 3:
Guru:
Answers
606
Questions
Helped
273960
Points
1197
The yellow wire is the cooling wire, it goes to the "Y" terminal. The red wire is the hot 24 volt wire, it goes to the "R" terminal. The green wire is the blower or fan wire, it goes to the "G" terminal. The white wire is the furnace or heat wire, it goes to the "W" or "W1" terminal.
5 Related Answers
A
Anonymous
  • Posted on Aug 16, 2008
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Anonymous
  • 540 Answers
  • Posted on Sep 03, 2008
SOURCE: got a honeywell t8400c thermostat
R--- rc or rh y--yellow g---green w--white red is power yellow is cool g--fan white is heat
Ken Bledsoe
  • 306 Answers
  • Posted on Jan 16, 2009
SOURCE: I'm installing a Honeywell RTH7600B
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
Anonymous
  • 108 Answers
  • Posted on Nov 01, 2009
SOURCE: Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Anonymous
  • Posted on Jan 10, 2010
SOURCE: Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Wires don't match the new thermostat posts. The wires from the furnace are Red,Blue black and white The posts in new thermostat are B O G Y not used R and Rc Can't figure which to put
The wire colors are for the following functions ......red - 24 volts white - heat yellow - AC green/blue - blower (fan) red is connected to the R with a jumper between R and Rc What type of furnace/heat do you have ???? Electric. oil, gas .Forced hot air, baseboard, steam, heat pump, or ?????? Different systems use different connections and need a specific thermostat for that application !!!
Hook ignition wire
This is a typical 5 wire setup. The colors can change depending on the person installing the system, meaning if the installer liked using BLUE for cooling instead of YELLOW, that's how he hooked them up. If YELLOW wasn't available, they could of used BLUE or BLACK, and visa-versa. But, the wiring below is the most common. If you have a heat pump system, it will be slightly different. Hope this helps!
R- Red- Power 24v
G- Green- Fan
W- White- Heat
Y- Yellow- Cooling
C- Blue- Common
I am trying to install a RTH2310 but I do not know where the wires go. Brother in law took old Thermostat off and did not write down where they go. I have a white wire, a red wire and a green wire. Back at...
In most cases, the wires are used as this: Red=Power, White=Heat, Green=Fan/Blower Motor, Yellow=A/C. The other wires, like the one hooked to the yellow will be the condenser wires going outside. The thing I'm not sure on, is that Honeywell Thermostats usually have the terminals marked with R,W,B,G,etc. If it does, then the wires will be as color coded and just hook them back up that way. You can also test to see if those wires are what they are supposed to be by jumping the wires. You can start with red since that is supposed to be your 24v power. Jumper red and green, you should get the blower motor on, jumper the red and white, you should get the heat to come on. Same goes for a/c as explained above. Any other questions, I will be glad to help.
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
2helpful
I have a coleman evcon gas furnace I want to change the termostat to a programmable thermostat I don't know where the wires hookup we have four wires red,white,yellow,green. I have a honeywell RTH230b...
The thermostat has terminals which are marked for color, R = red, W = white, Y =yellow, G =green. There should be a jumper between Rh and Rc, Hook the red to Rh.
2answers
How to wire a Coleman proprane furnace
I just bought a houseboat with the same furnace in it.  I will check it this weekend and provide you with the wiring directions should you still need them.
Replacing the thermostat, took the old one off without marking the wires. Hooked it up by color and we get the furnace when we put it on cool. wires are green, red, yellow & blue (ground wire)on the...
the normal wiring for stats is white=w=heat,red=r=24volts,green=g=fan,blue=c=common,yellow=y=cooling.
see what ties into your furnace board and match the terminals.
Top Coleman Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
