Air sensor failure
To resolve, follow these steps: 1. Gently pry off the top hinge cover. (You may wish to use a flat tool, such as a flat head screwdriver. Do not use a sharp tool, such as a knife; you must take care not to accidently cut wiring under cover.)
2. Check to see if wiring has come disconnected
3. Reconnect the two white plastic connectors
4. Gently tap hinge cover back into place
If your display is malfunctioning but you've found the wiring to be connected correctly on your wine cooler, i would contact Vinotemp
SOURCE: marantz sr4400 a/v reciever. displayes error code
Error code POWV5 refers to a problem with the 5 Volt dc supply to the Digital/Audio PCB. If it's not a loose conection then the Main PCB is normaly the problem.
SOURCE: What does this error code mean and is there a quick fix for it?
F5=no resistance on the sensor drive circuit in the control.
