SOURCE: Bissel 7920 Diverter Valve Install
With the top cover off, turn it over, put the knob in the water only setting, the piston will fit in the slot (only one way), turn the knob some so it will stay on. Put the cover back on, but just before you push it down, turn the knob to the water only setting again, then push the top cover all of the way down. Turn the knob, you can feel if it is in the chamber or not. If not, it won't turn or be hard to turn.
SOURCE: Do i really need a special tool to remove engine on atv?
nope. get the tool... you will damage alot of stuff if you try other methods. just get the tool.
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
SOURCE: My valve cover is leaking. Do I need any special
ANSWERS to Both is NO if you have Minimal Skills you can Do it Yourself
SOURCE: 2003 bonneville rear brake job. Do I need a
Once the caliper is taken off the rotor a screwdriver can pop the pads off. New pads will have metal spring clips to attatch back on the same way.
