SOURCE: coleman powermate 6250 mod# PM0525303
I had the same problem on my Powermate 525500 (5500 watt) and finally manage to get in contact w/Powermate (PRAMAC) tech support. He told me that if the gen is setup for a while, the exciter loses it's magnatism. To reenergize ( jumpstart) as he called it, follow the prcedure below. Probably not for amatures.
1. start up the generator.
2. Pull off the brush cover on the end of the gen.
3. Get a 6-12 volt battery and setup w/color coated cables.
4. place the negative lead on the left side brush terminal and tap the right side brush terminal w/ the positive lead.
5. Wala....you sould have power.
One would think that this important info would be on the manual or a blog somewhere.
Good luck and have a wonderful day.
The Texajun
SOURCE: MI CADILLAC CATERA 99 PASA ACEITE A EL DEPOSITO DE ANTICONGELANTE
tu problema no eran las cabezas sino un enfriador de aceite que se esncuentra en medio del motor por debajo del multiple de admision lo puedes identificar por las dos lineas gruesas que se le conectan, su funcion es enfriar el aceite del motor pero hay defecto de fabrica y la agencia te repone el motor gratuitamente o puedes comprar la refaccionen la agencia la cual viene perfeccionada por el precio de 350dll
SOURCE: I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: que tipo de aceite es
utilizar 10 W30 de aceite y un filtro de WiX. El l?quido de la transmisi?n se comprueba y se llena a trav?s del tap?n de drenajesuperior en la parte inferior de la bandeja de la transmisi?n. El l?quido tiene que ser bombeada en mientras se est? ejecutando ycaliente hasta que empiece a agotarse. Toma ATF DEXRON
