SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
SOURCE: cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
SOURCE: mic wiring for a cobra 85 base cb
Pin 1 is shield, thats the bare wire wrapped around the mic audio wire
pin 2 ic mic audio [usually white)
pin 3 is transmit or push to talk usually red
pin 4 is recieve or speaker complete usually black
SOURCE: condenser mic wiring for cobra cb radio
1- shield
2-audio
3-transmit
4- recieve.
Any condensor mic will work just fine.
