Question about LG Computers & Internet
Lg tv 32LS3400 don't have power supply. Already check the pinout and I have just to pin with 3.5V.
6ya staff
SOURCE:
Anonymous
SOURCE: 3350 power connector specs
The Pin Assignment is as follows:
Pin 1,4: +5V
Pin 2,3: not connected
Shield: Ground
The AC Adaptor is specified as 5V , 4Ampere. Actually the unit draws around 2-3 Amperes.
/ 3 1 \o
\ 4 2 /
This "Image" shows the pins, when you look onto the jack at the back side of the terminal, with the terminal standing upright. The label = 5V is located left of the jack
Posted on Feb 29, 2008
ROD GANDY
  • 1602 Answers
SOURCE: Pinouts for DPS 1200 eb a /24 pin
CALL A LOCAL COMPUTER CABLING SPECAILIST AND SEE IF THEY CAN HELP YOU WITH THE PIN OUT
NEED MORE HELP CONTACT ME
CANDYMANGANDY
Posted on Jan 29, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Need Service manual for a RCA D52W19 Projection TV
You can get one at the following link. They email then within minutes. Heres a link to the correct Manual as Thomson makes those TVs for RCA
http://servicemanuals.vstore.ca/product_info.php/pName/itc222/cName/thomson
Posted on May 30, 2009
gripfitter
gripfitter
  • 557 Answers
SOURCE: Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
Posted on Dec 20, 2009
jpvan2010
SOURCE: Power Supply V-amp 2 Pinout Diagram
Don't have the pin lay out but the power supply is a transformer with two isolated secondaries. The blue & brown leads come from the 20VAC 200mA and the black & white 11VAC @ 800mA windings. I used two doorbell transformers (and a rheostat for the 11VAC section). The reason for two transformers is the secondaries MUST be isolated or something will fry!fb818bb.jpg
Posted on Sep 15, 2010
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Need pinout for power supply alesis 1622 p4
they have one already make 5 pin to 4 pin 3 dollars computer shop
Dec 20, 2013 | Asrock P4i65G Motherboard
614-0037 pinout
I don't know that anyone has ever done a pinout of that custom vintage Apple Quadra/PM power supply. You may have to be the first! Let us know how it goes.
Oct 25, 2013 | Computers & Internet
Will a NVIDIA GeForce gt 610 graphics processor work on a Dell Dimension 2400 PC Desktop
YES, Zian it will work....BUT,....................
1) It is a PCI graphics card, and uses a PCI expansion slot.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2898922&CatId=319
The Dell Dimension 2400 Desktop PC's motherboard, has three long white PCI slots,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105465
http://www.ebay.com/itm/Dell-Dimension-2400-Desktop-Motherboard-System-Main-Board-F5949-K5148-G1548-/190750417467?pt=Motherboards&hash=item2c699c623b
http://en.wikipedia.org/wiki/Conventional_PCI
If one of those long white PCI slots is open, you can use a PCI graphics card.
Concerned that the graphics card uses DDR3 graphics memory, and your computer only uses DDR Sdram ram memory?
Don't be.
The graphics card has it's own processor (Graphics Processing Unit), and graphics memory.
It runs independent of the system resources; the Processor and Ram Memory.
http://en.wikipedia.org/wiki/GPU
The concern is the Power Supply.
Original power supply's maximum rated Wattage is either 200 Watts, or 250 Watts.
The above graphics card requires a minimum system requirement/power supply requirement; of 300 Watts.
I would recommend replacing the Power Supply.
(Especially with it's age, if it is still the same one)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
ONE thing though..............
Watch the 20-pin ATX main power cable connector, and the wires in it. Be sure they are in the standard place setup.
Check the pinout, and color code of the wires,
1) Dell Dimension 2400 desktop computer, 20-pin ATX main power cable connector pinout,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105612
2) STANDARD 20-pin ATX main cable connector pinout, and color code of wires; as set by JEDEC,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[Be aware that the ATX main power cable, and connector, you get with a new power supply; such as the above, will have a 20 =4-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Use the 20-pin connector, tie the 4-pin power cable up out of the way]
For a time period Dell was making the motherboard's main power cable connector - Proprietary.
Meaning they has that motherboard connector wire pinout changed.
Colors of wires were in a different place, than the standard setup by JEDEC.
Orange wires are 3.3 Volts (DC)
Red wires are 5 Volts (DC)
Yellow wires are 12 Volts (DC)
Black wires are Ground wires.
Guess what happens if a 12 Volt Yellow wire, is plugged into where a Black Ground wire is supposed to be?
ZZZZZZzzzzt! Motherboard fries, processor fries, ram memory fries, and graphics card. (If used)
Check the color code of the wires, in the 20-pin ATX main power cable's CONNECTOR, for the Dimension 2400's power supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Dell Dimension 2400 PC Desktop
Lg-32LS3400 scrambled
re check the connection from the component input and tuner. then at the same time the system that you have using like NTSC or PAL, SECAM select the appropriate in your location.if still the same problem contact the supplier sine it was covered by warranty they checked the unit for free.
Sep 02, 2012 | LG 32LS3400 32" Class LED 720p HDTV
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Dec 28, 2010 | Computers & Internet
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
I got this Pacific Digital model 1930-24 in a yard sale. It needs a power supply/adapter. Where in canada can I purchase one and is this power supply common. I have a disc drive back up unit for my PC that...
Possibly not. It depends on what the power points are on the connector. The Pacific Digital 1930-24 uses the following pinout voltages: 1 = +12VDC ; 2 = +5VDC ; 3 = RTN/CMN ; 4 = +5VDC ; 5 = RTN/CMN. The pinout DOES NOT follow a clockwise or counter clockwise position. The pinout starts at the bottom with pin 1 by itself, above it is Pin 2 & 4 above that. On the opposite side is 3 with 5 on top. Or you can view the following image: http://img7.imageshack.us/img7/7204/minidin5p.gif
Again, that is the pinout for the socket on the 1930-24. Some iOmega external CDRWs have the +5VDC and RTN pins swapped. So they would not be a good alternative to use.
Jul 25, 2010 | Pacific Digital X-treme CD-RW Burner
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
Computers & Internet Logo
98 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
