SOURCE: Kenmore model # 25800-25801 Error code E1?
unit has a sealed system leak call sears for tech support 1-800-905-9505 it is under warranty
SOURCE: Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
SOURCE: E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
SOURCE: Airconditioner Model ICES-003
download the manual here.
http://www.retrevo.com/support/Danby-DPAC8020-Air-Conditioners-manual/id/886bh630/t/2/
