Firearms Logo
w
william c horton Posted on Oct 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to adjust sights on the AK 47 - Firearms
Ooglie
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 76 Answers
  • Posted on Oct 21, 2018
Ooglie
Expert
Level 2:
Night Owl:
Answers
76
Questions
0
Helped
54041
Points
210
A good place to start is with good old fashioned google...
Here is an article from there and gun digest
https://www.google.com/amp/s/gundigest.com/more/how-to/sighting-ak/amp
Kenneth Walker
Level 2:
Sergeant:
  • Expert 293 Answers
  • Posted on Oct 20, 2018
Kenneth Walker
Expert
Level 2:
Sergeant:
Answers
293
Questions
0
Helped
93185
Points
736
Take it to your local county sheriff, they know how to handle Kalashnikov rifles.
1helpful
I have a s&w m&p 40 cal and would like to know how old it is. The serial # is hss4521 any info would be appreciated.
The 40 S&W cartridge is you key. It did not exist prior to 1990 as it was a response to an FBI shootout in which the criminals were armed with automatic weapons (AK-47s).
Write to S&W Customer Service department and they can give you more information.
Oct 13, 2018 • Firearms
I need a rear sight for a Daisy air rifle model number 225.
Search the web for Daisy air rifle collectors. There is someone out there with your part.
Jul 03, 2018 • Firearms
Trigger pressure adjustment for musgrave target rifle,how do you?
Musgrave triggers were set at 2 pounds pull weight at the factory. There are two screws with lock nuts on them in the trigger assembly but they only alter the engagement between the trigger and sear, effectively shortening the travel needed to release the striker. This does not lower the trigger pull weight. You have to remember that in a bolt action rifle, you are pulling against the firing pin spring which in some cases can be quite heavy in terms of compression rate of the spring. Since most modern rifles ship from the factory at 4 - 8 pounds of pull, your Musgrave trigger is pretty light at two pounds. Using this in competition requires a standard pull weight, and your job as the shooter is to keep the rifle sighted in through the pull of the trigger past where the weapon fires a cartridge. The follow through is nearly as important as the actual aiming of the rifle. My advice is learn to live with the 2 pound pull.
Jun 09, 2018 • Firearms
1helpful
2answers
What are the most expensive rifle scopes?
Nightforce, Leupold and Schmidt-Bender Scope will get up there in the price point. Schmidt-Bender glass especially will be quite expensive. Their high end glass can easily exceed $10,000.
Jun 04, 2018 • Firearms
What is the thread type and size of the retaining screws on a Benjamin Franklin 347 Air rifle rear sight
Probably American inch pattern thread. A decent hardware store can measure the thread in the hole and tell you.
Apr 05, 2018 • Firearms
2helpful
3answers
Do I need fully multi coated Spotting scope or Rifle scope?
Scopes with fully multi-coated internal glass-to-air surfaces (lenses) are recommended as they allow the highest level of light transmission through the binoculars (90 - 95% of the light that enters the binoculars will reach the eye) with limited internal light scattering and reflectivity. This results in fully multi-coated binoculars, spotting scopes and rifle scopes producing brighter, sharper and higher contrast images than coated or multi-coated binoculars. Unfortunately, fully multi-coated optics are more expensive to manufacture and are often only incorporated into higher-end binoculars, so your choice may depend on budget.
Mar 22, 2018 • Firearms
Top Firearms Experts
vince
jws1013
Kolbrun...
Are you a Firearm Expert? Answer questions, earn points and help others
