SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
SOURCE: replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
SOURCE: Yellow Wire has no power
Your stock radio should have had a wire that does this. It may not be yellow so look up the wiring diagrams for your car. If you can't find it by doing that, then look up a diagram of your use box. Sometimes there's a diagram on the back of the fuse panel cover or somewhere around there that tells you what fuses are from what. You can then run a new wire if you have to.
SOURCE: every time i try to hook up my cd player to my
this can be one of three things
1) the fuse on back of CD player could be blown
2) you need to push and hold the src/pwr button till unit powers on
as long as the yellow and red wire are attached to the positive battery wire you are good if the ground is to the battery ground and you try the first two steps i said and nothing happens........
3) ground the black wire from back of the CD player to any metal surface on the golf cart than try the first two steps again
it should power on if this is the case
hope i was able to help you
SOURCE: How to wire KD-S741R CAR STEREO - WIRE COLOURS ???
older pioneers:
2 x green (1 with black tracer) left rear spkr (black= negative)
2 x white (1 with black tracer) left front speaker
2 x grey (1 with black tracer) right front speaker
2 x purple (1 with black tracer) right rear speaker
Lower connector
1 x red ignition (switched supply)
1 x blue antenna output power (may not be not used)
1 x yellow Illumination (radio button lighting)
1 x orange permanant Battery supply
1 x black vehicle GND
If still not working swap yellow and orange wires! will not cause damage
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
