What brand and model are you talking about? You can see the information you need on a specialized website about heat pumps
http://www.andersonheating-air.com/samsung-heat-pump-troubleshooting/
Yes, it should be constant duty. You could probably look at the nameplate for more specific info.
SOURCE: heating & AC thermostat problem
It could be running in a "programmed mode" if it has the capabilities. You could exit from the programmed mode
SOURCE: how do i operate thermostat and furnace
if your furnace is on 24 hours straight, before it heats up your home, then either your cold weather and indoor temps are extreme, or your unit is grossly undersized. if however your furnace cycles on and off when the temp is still way colder than you have set it you have either a bad stat that thinks its hotter than it is, or a bad furnace problem and even though the furnace is getting a signal from the stat to heat it is failing to do so. you'll have to watch and think this through to isolate the problem. if you set the furnace to max heat and it runs and heats the house reasonably quick then its probably going to be a bad stat. if you set it to max heat and it shuts off way before it gets to setpoint then the problem is in the furnace. be sure filters are clean, blower wheel is clean , returns are no obstructed, etc. if you by chance have an old mercury bulb stat they had a thing in them called a heat anticipator which basically worked like this. a dial with a little pointer determined how soon it would be till the furnaced reached the desired temp and anticipated how soon to shut off the burners in anticipation of the cool down period so you dont overshoot the desired temp. if these are bad or moved to different setting they can short cycle the furnace on of on off etc. or shut down the burner almost as soon as it lights. setting is usually at .4 to .6 on most, but really a digital stat is only way to go. by the way check to be sure you don't have a hot air supply grill blowing directly on the stat or it will shut off as soon as stat gets hot and rest of house will be cold. usual location is 5 feet off floor directly over the main return air grill or under it as the case may be. good luck
SOURCE: Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
SOURCE: Unit blows out cold air while on dehumidifier
Liz; Check for a fuse somewhere in the heat circuit. The master breaker in the house panel also
SOURCE: Oven heats, but does not get to correct
when you first turn it on both elements should come on(your top element may be burned out)if so turn breakers off just take out the screws on the mounting plate pull out and take wires off and replace
