Is it a 1/4 cup of soap? is it less? also do I need to add a rinse aid as well if so how much of that do I add?
Hobart commercial machines are designed to run with commercial chemicals. There will either be an internal dispenser or an external unit supplied by the chemical supplier. Rinse aid is dispensed directly into the boiler. Detergent to the wash tank. The chemicals used are commercial strength so not required in the same quantity as domestics.
SOURCE: chalky dishes in dishwasher
the problem is hard water. this is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
SOURCE: E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
SOURCE: what does add rinse aid and where do you put it
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
SOURCE: Cannot unscrew cap on rinse aid compartment in door of Whirlpool Gold Quiet Partner III
the cap doesn't come off, you just have to open the door all the way. then, when you pour the rinse aid into the dial area, it will get sucked into the dispenser. but if the door isn't open all the way it won't go anywhere and will overflow on you.
SOURCE: Dishwasher rinse-aid dispenser not working
the film is caused by hard water. go to www.dishwasherfilter.com. they have a product out for this exact problem. works amazing every time and is very affordable.
