SOURCE: need correct setting for 30 yr old upright Kenmore freezer
depend on the type of control you have on your box ,,,, best is if it shows 1-7 set it on 3-4 ,, if it has letters set it on C ,,, eather way set the control on mid-point and it will work fine.
Larry
Your best bet is to start in the middle. Guesstimate and let it run. The test is to see if water freezes solid in 6-8 hours. If not, you can turn about 1/4 turn or less. Then you can try hamburger meat which a lower freezing temp and see if it gets solid. Your perishable items should be put somewhere else until you are ready. At least the water frozen will keep the meat safe from bacteria growth or spoilage. Let me know how you do.
