SOURCE: Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
SOURCE: old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
SOURCE: Gas Burner ignitor is not working
Yes it should be an easy fix.
Ignitors simply go bad from time to time.
If you have a meter you can check to see if you have voltage going to the ignitor. If you do, and it isnt trying to ignite, replace the ignitor.
If you have no meter, ignitors are usually less than 30 bucks so you will not be to much in the hole by just replacing it.
If you lift the cover to access the ignitor, it should be held in by two crews, the gas tube, and a wire to the flame sensor.
Make sure you turn off all gas and electric before disassembling.
You can find ignitors at your local appliance parts supply house.
All you need is the model and serial numbers.
SOURCE: Wolf cooktop 5HR light keeps turning on. Pressing
Turn off power to the cooktop (i.e., using circuit breaker if needed) for 15-20 minutes. Once turned power back on, problem disappeared for me. The semiconductor needed to be reset
SOURCE: Front burner won't ignite when turned on.
Hello there:
if you Heard or seen this poping you probably have shorted out the ignitor mechanism You can try unplugginh the stove and removing the part and inspecting it and see if it can be cleaned and doubkle check the wiring to see ithatthey are not greasy or there is any buiold up on the wires then reinsert the part and see if it will work now but if not you will have to replave the ignitor ok
If you have a local appliance repair center you should be able to get the part from there if not go online and go to www.repair clinic.com youcan order it from them ok
Hope this is very helpful for you
Best regards MIchael
Testimonial: "Thank you so much for your help.I am definitely going to take your advice. Working on it right now. Much appreciated."
I appreciate your post, friend!
I noticed your question is labeled under Frigidaire cooktop model, FEC30S7E. I have located the Use and Care Guide for your cooktop and I was unable to locate a lock feature. You could perform a reset on your appliance and you can do that by unplugging the power cord or flipping the circuit breaker off for ten minutes.
If that does not correct your issue could you please provide me with your model number? Usually you can locate the serial tag (which lists your model number) inside your burner box or on the outside of the appliance base. With that information I can look further into your model. I look forward to assisting you. -Matt
