GPX S7794 is a home music system with turntable, cd player, radio, cassette player/recorder.
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
SOURCE: AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
SOURCE: I have a GPX model
Your Electric motors are not getting enough power from your power suppy go in and make sure all the wires are plugged securly into their connection. This should solve your problem.
SOURCE: I have a Denon DP-51F turntable. It was fine the
Hi, it has seized from lack of use. Disassemble and lube it. [email protected]
