Bought used power painter at yardsale. Cleaned and oiled everything. Looked for wear on piston as recommended. Everything seemed to work and it sprayed water fine when I tested it. Tried to use it on an actual job and it wouldn't spray. not enough compression to spray thompson water seal? Is the piston bad?
Maybe just plugged. If it has the nozzle that can be rotated 180 degrees, roll it and try to spray. Sometimes a bit of debris gets in there and stops it up. If no on the rotatable nozzle, take the tip off and try to push liquid back to the container, or a waste bucket, to clear the line. You also may need to clean the tip. One last item.....since you sprayed water.....if you chased the water with the TWS, you may have made an emulsion. If so, remove the spray gun, and turn on the pump, pumping into a waste container, until the emulsion is displaced. Clean the gun. I'd say that if it'll spray water, TWS would be even easier.
Regards, --W/D--
