Phones charge if placed in the base unit but the base unit will not power on the answering machine. It will not display "in use" either. Can not re-register handsets in the base unit.
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: My cordless phones need to be registered
Press menu button, the LED readout should say "press pager button and wait for beep".
I have a GE21900FE1 and it worked perfectly
SOURCE: Cordless handset phone will not connect to base
A Microprocessor Problem, beyond ecconomical repair.
AL
SOURCE: Registering handset to base
Reset button on back of rectangular base unit (black and hard to see) - press it down and hold while you choose 'register handset' - should pick it up immediately.
