Contact Timex
https://www.timex.com/watch-manuals.html
For any questions or support click here or call
1.888.727.2931 Mon to Fri
4am - 7pm EST
SOURCE: How to change battery for Timex Indiglo WR 30M
I second the vice advice...the only thing that worked was to put it in a vice and crank it one more crank then you think is possible. You will hear a little "pop" when it snaps into place. It was the only thing that worked!
SOURCE: Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
if you don't hear anything, you've turned off the hourly chime! if you hear two short beeps, you've turned on the hourly chime. turning the chime off/on is cyclic. if you press once and hear nothing, it's off. if you press again, you'll hear two beeps and the hourly chime is now on. a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off. i hope this helps someone.
SOURCE: Alarm on timex indiglo won't turn off
It's just a cheap watch, one hit with a hammer and the alarm stopped.
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
