t
teddy Posted on Oct 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My konical minolta bizhub c451 has3425 error code. i have try but no respond even holding down the ultility/counter key down as i turn on the machine
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Oct 20, 2018
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910507
Points
11959
WARNING: DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
5 Related Answers
steven brickhouse
  • 19 Answers
  • Posted on Apr 16, 2008
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Aug 23, 2009
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Anonymous
  • Posted on Sep 15, 2011
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
How can I correct error code c3822 on bizhub C451
1. Turn OFF the main power switch (Inside front cover). Ensure sub power switch is on located right side of the control panel)
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. If the code come back do NOT reset have a tech come out replace the fuser unit, it can catch on fire that will ruin a Christmas Day!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Customer has C451 bizhub that has unresponsive control panel except it will make ONE copy after hard reboot. Then no buttons work, particularly the Utility/Counter button. Can't get in to service mo
Hi
The bizhub C451 is a Konica-Minolta machine and I have found a webpage here:
Error Codes Konica Minolta bizhub C451
that details the error codes that can occur on your machine. I know that this may not be of much use as you don't appear to have any error codes appearing. However, there is also a link at the top of the page from which you can get a copy of the Service Manual which will probably have a lot more detail in it and may answer your question.
Hope this is helpful, if so would you please register that with Fixya
Cheers
What is Code C-3725 on Konica Minolta Bizhub c451
C3725 Fusing abnormally high
temperature detection
(NS sensor)
• The NC sensor continues to detect a temperature
higher than a predetermined one
for a predetermined period of time.
Procedure for resetting
1. Turn OFF the main power switch.
2answers
Error C3102
The Fuser is not turning... follow these steps
2. Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
5. After turning off the main power switch, wait 10 seconds and turn the machine back on, this should reset the service code and with any luck the machine will run!
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
2helpful
2answers
Bizhub C451 error C-3924
c7ff0589-2c1c-428b-8214-5be985c427d0.jpgkonica minolta c451 printing problem
How do I clear error code C3B04
Turn the machine completely off with main power switch inside machine then holding down the Utility/counter turn the machine on and close the door ensure sub power switch is already on that's the one on the side of the op panel wait to see Trouble reset on screen touch should read OK then power off then power on WAIT TEN SECONDs ALWAYS BEFORE powering back up. If the code comes back need a new fusing High Current Board. Some serious bucks:(
5helpful
2answers
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Error message c 3725 konica minolta c 550
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Error message 3725 on Bizhub C451, how do i reset so I can print
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
6helpful
2answers
Minolta bizhub c 351 code c 3451
this error code means the fuser rollers failed to heat up you can reset the code by turning the machine off and hold down the utility\counter key while you turn the machine onwhen the trouble reset button shows on the touchscreen touch it and when it says ok turn the machine off then back on if the machine gives this erro again you will have to have the fuser replaced
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
