SOURCE: 1- Panasonic 7'' monitor model # CQ-VA707WEUC
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
SOURCE: CD radio code for Panasonic cq- c111oan pao41741130995 fa08606
check your log books or you can get it from dealership if its the original if not the manufacturer
SOURCE: CQ RDP162N
i can get a general wiring diagram for now need to look into it sum more
Typical Head Unit Wire Harness
Function
Typical Wire Colors
Memory / Constant 12V(+)
Yellow
Switch / Accessory
Red
Ground
Black
Illumination
Orange/White
Antenna Remote
Blue
Amp Remote
Blue/White
Left Front (+)
White
Left Front (-)
White/Black
Right Front (+)
Grey
Right Front (-)
Grey/Black
Left Rear (+)
Green
Left Rear (-)
Green/Black
Right Rear (+)
Violet
Right Rear (-)
Violet/Black
SOURCE: i lost id code security code use radio
Unfortunately radio codes for the VW Panasonic radio (using the Serial Number) will not be available for free from anywhere on the Internet.
Try your Main Dealer .....or a Decoding Service (who will plug it into a laptop to read the code in your radio memory chip )
SOURCE: radio Code for unlock 1999 honda CRV car
HONDA codes are not readily available from anywhere on the Internet apart from here
https://radio-navicode.honda.com
You will have to quote the car`s VIN number + other details.
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
