SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
SOURCE: Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
SOURCE: Oven heating element
Hello rvready
Welcome,
You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom
heating element has gone out. Oven is still in good shape so we'd like
to be able to find an element replacement, but have had no luck finding
one.
unfortunately,
I am not able to find this part either.
Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
Today's appliances save you the arm and the leg that such an old oven is costing you.
You have no idea how it is sucking your money out of your pocket!
It is unfortunate, that no one told you about this years ago!
You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
Shop for a new one and see your bills go down.
my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
That means I threw away $7000. in 6 years with my old world attitude.
Yes I am old fashion and always fix it!
But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
Hope I saved you some bucks with my real life stories!
Don't tell your wife!!!
Huuum
SOURCE: how to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
SOURCE: how do I remove aluminum foil from the bottom of
To all those who think this problem description couldn't be true, you're wrong. You're right that the aluminum did not get hot enough to melt though.....What happens is that the non-stick teflon coating they put on the aluminum get's too hot and bonds with the oven bottom.... like a crazy epoxy!
Furthermore, this isn't a problem in older, conventional-type ovens... this is moreso a problem with ovens that have a hidden bottom element.... The bottom element is actually directly below the oven bottom, and lining the oven bottom with foil is basically like putting it directly on the element. And that part gets extremely HOT!!!
Thankfully I've got the solution to this! But it takes some extreme patience, a lot of respect for what you're working with and some good ventilation.
I went back to my high school chemistry class to get the answer. It's Lye, aka Caustic Soda aka, Sodium Hydroxide.
I used Drano Kitchen Crystals off the shelf of the grocery store..it's about 70% lye with some added salts to aid the chemical reaction.
You'll need some plasticene, the drano, water, GLOVES!!, a lot of paper towels and wood skewers and GOOD VENTILATION.
Start the ventilation and open a window or door.
Put on your gloves.
Use the plasticene to create a dam about .25"-.5" high around the area in the oven you're looking to remove the aluminum from... the area's you're working in should be about 2.5" in diameter.
Pour in some of the drano into the dam and add enough water to touch all the sides of the dam......if the chemical reaction hasn't started (should be almost instant) keep adding the drano bit by bit until it does... the dam contents will start to boil and ammonia fumes and a little hydrogen gas will form....... hence the need for some good ventilation!!
Once the reaction is done, poke around with the wood skewer to see if the oven bottom is clear... if you're satisfied with the results, add some some vinegar in to help neutralize the solution a bit.... then use the wood skewer to remove the plasticene dam to a dish to be rinsed off ASAP.
Use paper towels to wipe up the mess on the bottom of the oven.... See your results! the area of the oven botton you treated should be free of aluminum and just be discoloured instead..... not from the drano, but from where the teflon bonded.
Repeat the process until the oven bottom is clean.
To get a 'feel' for the chemical reaction and what to expect, experiment first!... take a square of aluminum foil, go to the backyard with the foil shaped in a littlebowl and place it on a dish or pan, add some drano crystals to it then add a little water... step back from the dish and try not to breath the fumes!.. the dish will be hot!!
It took me about 6 hr to clean the bottom of my oven when this happened to me.
Hopefully this helps some other poor unfortunate souls who finds themselves in this situation!
